Projector output in Arena
Leo Souza
Post by Leo Souza »
It seems that arena could not detect my projetor (epson power lit S6+). Whatever I do (change to omega driver, 3d settings) doesn't work. Arena always shows me a display 0x0 in output menu and can not send the output window to the projector.
I'm a win 7 64, gtx 460M user.
Please, need urgent help.
thanks
Basic
Re: Projector output in Arena
Post by Basic »
are you able to get dual screen?
Leo Souza
Post by Leo Souza »
Yes,
The only way that I found to solve this is to set the second monitor as main display.
Is it correct? Why do not put this in documentation?
Basic
Post by Basic »
im not in front of my laptop right now but main display for me is normally 1.
I have heard people mention what you've said, but if it works it works i suppose. Have you done a search of the forum? Im sure this has been posted before :)
Leo Souza
Post by Leo Souza »
I think that this should be a problem of Nvidia. I found this:
http://www.howtofixcomputers.com/forums ... 35489.html
I do not know if has been solved since 2009. But I would like to know if someone has this problem.
Leo Souza
Post by Leo Souza »
Hi again,
this seems to be my problem, but the solution indicated does not work with my gtx 460M Nvidia driver version 285
http://www.resolume.com/forum/viewtopic ... lay#p29585
Leo Souza
Post by Leo Souza »
I have notice that:
The scroll only moves by pressing the mouse's middle button when the mouse is in movement. If the mouse is stopped it is not possible to scroll.
Besides I have downloaded the new 290 beta drivers for my GTX 460M and Have notice that:
1) The problem related persists.
2) When the resolution of the second display goes to 1024x768 the problem is solved.
3) Audio is no longer working. Even in video or in a wav file.
4) It seems that resolume with 290 nvidia driver slow down compared to 285 driver.
after resintalling resolume all of this has been solved
It seems that if the driver is updated, then Arena shall be reinstalled.
And if the resolution of the projector is 800x600 then Arena shows a [0x0] in advanced output
