ATI FirePro 2450
ATI FirePro 2450
Have anybody worked with this runs it Good? any remarks
Re: ATI FirePro 2450
hmmm...it's not comparable I think....
The only experience with a FirePro model was the FirePro8800....and yes...this card runs good!
Greetz
Greetz
Do you like outlines? Easy Outliner on Juicebar Re: ATI FirePro 2450
du meinst die ist nich Kompatible?
warum...
warum...
comparable means vergleichbar
Kampatibel heißt compatible
Besten Greetz
Besten Greetz
ok dann werde ich mal schauen was die kann...
than will i post the experience i made with
