LOW FPS in Arena 4
kingafro
LOW FPS in Arena 4
Post by kingafro »
I have a Low Frame Rate 6fps and lower...
System Configuration:
Microsoft Windows 7 Ultimate
Version 6.1.7601 Service Pack 1 Build 7601
Systemhersteller Dell Inc.
Systemmodell Precision WorkStation 490
Systemtyp X86-base PC
Prozessor Intel(R) Xeon(TM) CPU 3.20GHz, 3191 MHz, 2 Core, 4 logic CPUs
BIOS-Version/-Datum Dell Inc. A08, 25.04.2008
SMBIOS-Version 2.3
Installierter physikalischer Speicher (RAM) 2,00 GB
Gesamter realer Speicher 2,00 GB
Verfügbarer realer Speicher 1,18 GB
Gesamter virtueller Speicher 4,00 GB
Verfügbarer virtueller Speicher 2,67 GB
Größe der Auslagerungsdatei 2,00 GB
SAS HD
GFX ATI FirePro 2450
Output A: 1680X1050 for UI
Output C: Trippel Head2Go @ 2048x768
Output D: Trippel Head2Go @ 2048x768
Comp Res :1280 X 960
5 Layers
any ideas what i can do to get more FPS (yes i shoot down all GFX Highlights in windows and the Index-service too)
will help more RAM or sds?
ty for any Help
Re: LOW FPS in Arena 4
- What kinds of videocodecs do you use?
- What resolutions does your clips have?
You can use GSpot to analyse your clips! Its free!
LINK TO GSPOT
Greetz
...I remember you asked a question about your firepro before.
I took some time to search for the FirePro2270 specs...
...And I must say...it's not a good card for Vjing...
FIREPRO2270
http://www.amd.com/us/products/workstat ... 270.aspx#4
This card only consumes 15W at maximum power....this is not very much.
Did you ever tried to play a 3D game (2009-2012) with your card?
Greetz
dirtyjohn_lv
Post by dirtyjohn_lv »
Related to the low FPS issue ...
I have noticed that while giving false FPS, the FPS output of Resolume seems to be following the refresh rate of the connected system.
If I am running Arena, with no external monitors (just laptop) I get ~60fps
If I connect DVI direct to my LED wall in Arena I get ~75fps (standard resolution for this wall is 1024x768@75)
If I connect to VGA-DH2G I get ~60fps
Connecting direct from laptop to a video processor also yields the same result. I will pick custom resolutions and Arena almost always seem to read the refresh rate as the FPS
Edit: The playback still works as expected
