resolume and the behringer bcf2000 midi
seex_
This is my first midi controler and im just starting to use it, i recomend a midi becouse you can control more than one parameter at the same time and controls of individual parameters are extremly exact. Emediety i noticed tht there is on midi control for effect bypass, is it possible to have this function written for 2.0 or is the effect oppacity enough? (Bart and eddy). Since the bfc2000 has no keyboard controlers it seems impossibloe to assign functions to the "other notes" functions, has anyone had sucess asigning a function to the push function of the roraty knobs or to the two on/off buttons right onder the rotary knobs?
Anonymous
try configuring the midi.
you can assign a controller or a note, its easy if you read the sections 4 and 5 of the manual
1. press edit
2. at the same time press the button
3. release edit
4. move the push encoder 1, in the screen will appear "note"
5. move the push encoder 3 to assign a value for the note (begin on 60, less values will show problems)
6. press exit
7. press store two times to save the configuration on the active preset
now you can assign "note functions" to that note
good luck
KIDVISUAL
__________
Don´t ask for songs, ask for loops!
1. press edit
3. release edit
6. press exit
good luck
KIDVISUAL
__________
