Preset
ctgigi
Preset
Post by ctgigi »
Hi
Is it possible to change Presets by DMX?
Ty
Re: Preset
Presets? Do you mean clipdecks?
greetz
ctgigi
Re: Preset
Post by ctgigi »
No, I'd change the presets (in the avanced screen setup windows of the output menu) in a show and would do it by Chamsys console.
Is it possible?
Re: Preset
Presets in the Advanced Output can not be triggered via midi or keyboard. The Advanced Output is intended to be set up before the show, and then to be left alone.
The need to switch between presets via midi has been expressed before by others, and we're aware of this demand for it. It's not going to be a high priority though.
