Resolume on SSD /HDD
vedder
Post by vedder »
hi all,
get i more performance if i run Resolume on a HDD(7400rpm) and my clips from a SSD?
or should i run both (Resolume + clips) from the SSD?
all on MacPro 2 x 2.93 6core / ATI HD 5770...
thanks for your ideas ;-)
vedder
mac pro / 2 x 2.93 6 core / 48 GB RAM / ATI HD5770 1 GB /
Basic
Re: Resolume on SSD /HDD
Post by Basic »
Sounds like a powerful system you have. What type of shows will you be running and what resolution will your clips be?
vedder
Post by vedder »
in this case a for 3 hour broadcast show. resolution will be 1024 x 768 (mapped on LC LED frames).
all clips are in the DXV codec and maximum running 3 layers (screen/key/multiplie - mode).
some have a length of over 30 sec.
i had some issue with smooth playback from a RAID 0, so i switched to the SSD (wich is/was my system disc).
