Hello there,
I noticed that in both Arena V4.0.0 and 4.0.1 that the OSC commands for cue set, cue recall, transport video scratch etc. . all work as expected on the factory clips included with example file, but as soon as I start a new project or even add my own clips to the example file, the OSC controls aren't working properly. . When I use my mouse to directly interact with the interface with new clips it does work fine though, so I think this bug is specific to OSC commands. .
I don't know if this would help you try and replicate my problem, but I'm using:
Macbook pro on 10.7.3
Resolume 4.0.0 & 4.0.1
TouchOSC
All of my videos are .mov compressed with the DXV codec
Thanks in advance!
Mike
IntenseSL.com
OSC Bug
Re: OSC Bug
It could be that your clips have audio (or have an empty audio track), in which case the address for the playhead and cue points is different (/activeclip/audio/ .... instead of /activeclip/video/ )
Hope that helps!
Hope that helps!
michaelmoore83
Re: OSC Bug
Seams like you nailed it. My clips do have audio attached to them. I just turn it all the way down on the clip settings.
For now, I'll change my iPad layout to say "audio" instead of video and when I have more time I'll remove the audio from the file so they are all the same as the stock audio-less clips.
Thanks so much for your quick response!
