help a starter, please:)
vera.ff
Post by vera.ff »
I am trying to learn already some things with Resolume: I was trying to add video clips, but I am not able to do it (to add them to decks and I have tried with .mov and .avi). I did instal the codec ( the dxv) also. Is it because I do not have installed an application to render these clips? I installed quick time player. It is not enough? I read that:
"The DXV Codec is a cross-platform Quicktime codec so you can use from any video application that supports rendering to the Quicktime (.mov) file format on the Mac and PC. Applications that are supported: Quicktime Player Pro, iMovie, Final Cut Pro, Motion, Adobe Premiere, After Effects, Sony Vegas, Maya, Etc".
Do I need to install one of these applications? What do you recomend? Can anyone help me with this?
Thanks!"
Basic
Re: help a starter, please:)
Post by Basic »
you mention installing with DXV, have you rendered your clips? do you have quicktime installed. Are you on Mac or PC?
vera.ff
Post by vera.ff »
Thanks for replying. It is working now:) By the way, is there a tutorial that you recomend? Thank's a lot:)
Basic
Post by Basic »
cool no worries, im glad its working. What would you like a tutorial on? Encoding of clips? :)
