Hey All!
I'm currently doing my master in graphic design and i'm working on a live performance with a band.
I was searching the forum and the internet but i didn't quite find the right answer.
So the thing is:
I want to use multiple live feeds (2-3) from dslr camera's but i found some information that some dslr camera's can't record and send an output at the same time, or isn't that a problem anymore? I want to buy a blackmagic design capture card to get the signal in resolume but i also discovered that most cards (inexpensive) only have one input hdmi port. Are there any other supported cards with more inputs, or do you just have to but multiple cards? And is there a big delay between the actual filmed image and the captured image in resolume?
I hope there are some people who have experience with this subject cause It would be a great help!
Thanks in advance
Dslr, blackmagic design and Resolume
Re: Dslr, blackmagic design and Resolume
You can buy an HDMI switcher that has many in's and 1 out.. That way you can connect your multiple cameras to the switcher and the output of the switcher goes into the capture card. So inside resolume you need only one source clip but you can change your live feeds through the switcher and thus show different live feeds at any point of time... Also your one input of the capture card is sufficient in this case
You can use more than one Blackmagic cards connected to the same machine. Or use a DeckLink card with multiple inputs, i'm not sure if they have a card with more than one hdmi connection though (they do have dual or even quad sdi input cards).
http://www.blackmagicdesign.com/products/decklink
I would get more cards. HDMI switchers take forever to change input and can be flaky. Of if you can get Component out of the DSLRs you can get a cheap a/v swithc that has component, use that to switch and run the one out from that to the BMD
