Constant crashes
Jinx75
Constant crashes
Post by Jinx75 »
Resolume has never been consistently stable for me, but I had a few months after an update where it was actually stable- after the last version of 3, it began crashing upon exiting the program, and now is frequently crashing upon start-up. I have been using several other vj programs with no issues, lag or crashes. I need to get this sorted or just move on to a stable platform for video work. I've sent a crash report- has anyone else encountered this? Is 4 stable?
vj granda
Re: Constant crashes
Post by vj granda »
Are you using 3.3.3 ???
Jinx75
Post by Jinx75 »
Yes, I'm using 3.3.3.
Let's handle this via the email you sent, because this post does not give enough info to help in any meaningful way.
asperi
Post by asperi »
I am having a ton of crashes on R4 too. 14 decks, all with 48 clips, all clips are Quicktime h.264 1920x1080 8.8mbps bit rate.
