Mark out
DoofBoy
Mark out
Post by DoofBoy »
resolume 2.2 is well de_Bugged well done Bart & Eddy.
The only problem so far is "Ctrl + O" doesn't seems to move the "mark out",
Althought "Shift + I " and "Ctrl + I" is working fine with the "Mark In".
has Anyone had that problem ?
edwin
Post by edwin »
hi,
you are right!
i checked the preferences and it seems that
the shortcuts for 'move in-point right' and 'move out-point right' are both in default set to Ctrl+i.
set 'move out-point right' to ctrl+o again in the preferences and everything should work fine again.
this will be fixed.
cheers
Edwin
