Hey there, seems that too much Flash-Clips in one deck makes Resolume crash after quite some time. The crashes occur randomly, always after switiching to a deck with multiple flash clips loaded.
best
b
Flash makes Resolume crash
- Bang Boom Ben
Re: Flash makes Resolume crash
Can you check your memory usage when using these files? Sounds like there is a memory leak somewhere.
