Hello '
Its as if there is a problem with the alpha channel processing and the chromakey plugin when using it with an HDMI input on the blackmagic decklink studio card.
When I apply the chromakey plugin it just goes straight black. nothing corrects this, I cant find any image no matter what I do.
Is anyone aware of a workaround for this? I bought the camera for this reason and need it to work, so Its a matter of my 25 days ending on the product return.
Thank you
HDMI input Blackmagic decklink studio Chromakey problem
Re: HDMI input Blackmagic decklink studio Chromakey problem
What sort of graphic card are you using? Can you send us your logfile (mail@resolume.com)?
Im on a Hackintosh acctually' so its going to be an insane fix, how do you get a log file from arena?
graphics card is HD Radeon 9670... Im upgrading to an Nvidia GTX 580 in a few days, Ill let you know.
Thank you'
Thank you'
Ah.
I'm afraid we can't provide support on Hackintosh models.Changing the GPU will most likely fix it though.
Good luck!
Good luck!
