Hey
Another probably minor bug, on macOS, Snowleopard, the mousecursor is visible in the output. On my windows7 notebook this does not happen.
Would be nice to get it hidden under Snowleopard as well.
Bests,
Marcel
Bug?: Mousecursor visible in output, MacOS
Re: Bug?: Mousecursor visible in output, MacOS
exact, same configuration for me, same problem...
To hide the mouse, we use a bit of code that will always put the output window on top of everything else. This way it should also hide any other windows that may pop up.
Works great on Windows, but it turns out that the only way this will work on OSX is when the output window is actually in focus. So when you click the output window, the mouse will disappear, but thanks to Apple there is no other way we can hide that fella.
Believe me, we're as annoyed about this as you are, but I'm afraid there's no fix for this.
a pity.
anyway, thanks for letting us know.
is it possible to lock the cursor to desktop only?
But i did seent this tooelieve me, we're as annoyed about this as you are, but I'm afraid there's no fix for this.
