Resolume 2.0 beta 2 locks up with dual screen
defje
Post by defje »
Hi all!
When i try to apply my screen setup settings, with normal dual monitor or DVD Max, resolume just stops and doesn't respond to anything.
My system is XP Pro SP2, on a Fujitsu Siemens Amilo D8830 with a ATI Mobility Radeon 9000. Like i said, enabling theater mode doesn't make any difference. In 1.5 it works fine. I also had this problem with the first beta.
I hope someone can help me out because i want to try it!!!! :o :D
TIA
defje
Post by defje »
Just installed Omega drivers, no difference. And my screen setup settings don't matter, just hitting apply makes resolume die.
anything i could try to turn off? like certain programs that could conflict?
[Edited on 13-10-2004 by defje]
Anonymous
Post by Anonymous »
Have you an audio driver installed ?
It was my problem...my audio controller was desactivated, i've installed it and now it works fine.
It seems that resolume needs an audio card to work properly.
defje
Post by defje »
thanks for replying :). but i have a audiocontroller.
Anonymous
Post by Anonymous »
Same problem here. I have a Radeon 9600 pro. Maybe it's got something to do with the Radeon card?
mision
Post by mision »
I have radeon 9700 and problem like others :/
Anonymous
Post by Anonymous »
Radeon 9200, same problems.
Anonymous
Post by Anonymous »
in the 2.2 it's working for me
