Mapping Issues
Myotte
Mapping Issues
Post by Myotte »
So Im not sure if this has been discussed before or not. I havent been able to find anything in my searching. Heres the issue:
I have all my columns mapped to be fired off from midi notes being sent from Ableton. The issue is this: whenever I delete a column that I don't need anymore, Resolume deletes ALL of the mappings that I have put in the entire application.
Any ideas of what is causing this and any possible fixes? Thanks!
Re: Mapping Issues
Have you tried using the Application midi map instead of the Composition midi map?
Myotte
Re: Mapping Issues
Post by Myotte »
I have not yet. Mainly because I literally have about 130 mappings that I would have to redo. I may make a new composition and try it with that first. Thanks for the idea!
