Capture through SDi
Roger39
Capture through SDi
Post by Roger39 »
I'm running Resolume Arena and I need to run a Powerpoint presentation from another PC over an animated background which will be played in Resolume. I need the Powerpoint to be high res, can I come out of the presentation laptop convert it to Sdi and then capture it with a Blackmagic Decklink Sdi card and use it in Resolume?
edwin
Re: Capture through SDi
Post by edwin »
Yes you can, we tested our BlackMagic support with the DeckLink duo (2x SDI) and it works great!
Roger39
Post by Roger39 »
Great news...thanx!
