Hi ..
witch tool i can use to convert my mp4 files to mov files with the right codec,
so that they run in resolume with?
or is that Problem only in the trial version?
thx ray
Convert my mp4 to mov ...
Re: Convert my mp4 to mov ...
Hi cosmowe,
Kannst du mir vlt erklaeren wie die Settings im streamclip einzustellen sind?
Hab das probiert aber leider kann ich die mov's nicht importieren.
weder per menue noch per drag&drop aus dem Ordner.
File > Export QT >
and now?
Ich habe:
Compression: DXV
Quali: 100%
Sound: no sound
Frame Size: unscaled
Rest hab ich so gelassen ...
Will ich das mov rauslassen kommt die Fehlermeldung: cant prepare video ...
nun hab ich aber gelesen das der DXV notwendig ist ...
Danke fuer jede Info ...
Ray
File > Export QT >
and now?
Ich habe:
Compression: DXV
Quali: 100%
Sound: no sound
Ray
Achso ..
andere compressionseinstellungen gehn im export > lassen sich aber nicht oeffnen im resolume ...
LG
LG
I thought you want to export to DXV mov? and not import a mov?leider kann ich die mov's nicht importieren.
You have to install Quicktime Player AND the Resolume Codec. If you already installed resolume the second point is already done!
THEN...
- Open Streamclip
- File -> Open File
- Choose your MP4
- File -> Export to Quicktime
- Compression = DXV
- Quality fader has no influence to your export result
- Unscaled
- No Sound ... except you want sound
- Interlaced scaling OFF ... I have no idea why this point is ON every time I open Streamclip
Thats it.... PRESS "MAKE MOVIE!"
I have no f***ing idea what you wanna tell me hereWill ich das mov rauslassen kommt die Fehlermeldung: cant prepare video ...
Greetz
Oh > in english .. ok ..
Will try settings and come back...
Hi ...
had barely time...
I tried but the settings doesnt work.
What can i do?
had barely time...
What can i do?
If that video doesn't clear things up, you really need to describe how 'the settings doesnt work', otherwise it becomes very hard for us to help you.
