I am running Resolume 4 on an Imac and a PC based laptop.  On the laptop, the effects are visible and I have been able to use them.  However, Resolume didn't run smoothly on this laptop so I switched to using an Imac.  Everything runs smoothly on the Imac however none of the effects are available.  Has anyone experienced this?  Can you make Resolume manually search for video effects?  Any solutions to this?
Joe
						Where are my effects?
Re: Where are my effects?
hi easy....
Resolume -> Preferences -> Video
under FreeFrame (FFGL) Plugin Directories "should" be the correct path to the VFX folder of your version.....
check it!
Greetz
EDIT:
This should be your path on OSX /Applications/Resolume [Avenue/Arena] 4.1.0/plugins/vfx
check it!
Greetz
EDIT:
 Do you like outlines? Easy Outliner on Juicebar Re: Where are my effects?
That worked!  Thank you.
