[fixed] Audio Problem with 4.1
rpacker
Post by rpacker »
I am experiencing an audio problem, which seems to worsen over time, until restarting. The problem is a breakup of the signal, reducing the sound to a static-like quality. It occurs intermittently so there doesn't seem to be a clear pattern. I am running Ableton 8.3.3 and Resolume 4.1 on a Mac Pro with 12 megs of ram, using the same audio interface (Ensemble), and routing the audio output back in the input in order to manipulate in Ableton. I tried routing the audio straight out of the built-in audio just to monitor the problem, and this doesn't seem to make a difference.
Has anyone else had this problem?
Thanks,
Randall
Mac Pro 8-core, 14 Gb ram, ATI Radeon 5770 graphics card, AJA Kona Lhe
Stickygreen
Re: Audio Problem with 4.1
Post by Stickygreen »
rpacker wrote: a Mac Pro with 12 megs of ram
Dood, 1994 is calling, and they want there apple IIe back...
LOL!
Rene
Post by Rene »
on OSX video FX are located here:
/Applications/Resolume [Avenue/Arena] 4.1.0/plugins/vfx
I didn't get it right...... does ableton or resolume delivers 2-Bit noises? ..or your 12MB MacBook? ;)
Re: [fixed] Audio Problem with 4.1
This was fixed by increasing the buffer size to 512.
ah... and again THE MIGHTY BUFFER! :twisted:
