[fixed] Snow Leopard does NOT like Resolume 4.1.0
digitalgigalow
Post by digitalgigalow »
Hello gang. I have a Macbook Pro with 2 hard drives. one is a disk and the other is a SSD. the Disk has Lion on it while the while the SSD has Snow Leopard. I was able to load onto my Disk HD and everything loaded fine, and I did NOT register it. I rebooted and booted into my SSD and copied the loader to my SSD. The package check was good and then I was able to load. I was able to go through the install and got the green check mark. I went to start the app and the app loaded and when it got to the point where the app loads the media provided, the app crashes. Now when i started the app on the on the disc HD, I had to relocate all the provided files, yet it ran smoothly.
What can I do to rectify this issue.
digitalgigalow
Re: Snow Leopard does NOT like Resolume 4.1.0
OK Gang. here is a link to a video capture of what happens. I am going to do a fresh install of Snow leopard, resolume 4.1.0 and ableton live 7. I was also noticing that ALL my video filter quartz composer patches were messed up and were not seeing my video camera and I had to reset all 800 patches. also my partner in crime loaded on his machine with snow leopard with no problems.
I do a fresh install on the SSD and check it out.
AND...Yes my OS is up to date.
https://www.facebook.com/video/video.ph ... 8005&saved
digitalgigalow
I did a FRESH reboot and still had an issue. I Hesitated for a day and decided that I should go ahead and upgrade to Lion. I formatted the hard drive and loaded Lion and got a clean install.
So is it working for you now or not?
digitalgigalow
It did NOT work the second time. I had to update to LION then it worked.
