Hi all!
Just wanted to know what the general consensus is on what's the more efficient thing to do:
Arrange the clips on an editing program and export them as one file...
or
Using many short clips...
or
Does it really matter at all?
Thanks,
chiz
ADVICE: a few long clips vs many short ones?
Re: ADVICE: a few long clips vs many short ones?
depends on what your doing really.
If you want to just play one long clip and loop it you can.
But if your vj'ing and mixing it might be better to have many short loops so you can mix freely between them.
I'd say most people use many loops to create many different composistions but there is no correct way.
Try each method and see what works for you
good luck!
good luck!
