I've recently put together my first AV performance using Resolume Arena, Ableton Live and MadMadpper:
This worked quite well under a controlled environment although there were problems with low frame rates etc at points so a few versions had to be recorded until one looked good enough.
I'd like to take this performance out live but have a few questions about the best way to do it. There is some money available for this so mostly it's about getting the best out of the equipment I have and what needs to be purchased to get this running smoothly.
The set up in the video consisted of one laptop running Ableton Live sending OSC messages (triggering videos) across a WiFi network to a MacBook Pro (i7 2Ghz, 4Gb Memory, AMD Radeon HD 6490M) running Resolume Arena and MadMapper.
The Arena project was running at 1280x720 with all the videos encoded using DXV and using lower resolution copies of the videos when 3 or more were playing at the same time.
Any suggestions for getting the frame rates higher and a more consistent performance? Is the bottle neck here the graphics card? Would using SSD drives help? Would splitting Resolume and MadMapper across two machines (using a video capture card) be a better idea?
Any help would be great.
Thanks,
Chris
Taking a show on the road (Noob Qs)
Re: Taking a show on the road (Noob Qs)
Hello Chris, IMO yuo don't need at all to run Madmapper for this set up, only with Arena is enough, you will get more fps and more stability...
The SSD option will increase a lot your laptop performance...
Cheers.
Cheers.
cevansroberts
Thanks for the reply. Unfortunately at the moment you can't change presets by MIDI or OSC (as far as I'm aware) in Arena. So MadMapper is used to take multiple output slices from one video slice e.g.vj granda wrote:Hello Chris, IMO yuo don't need at all to run Madmapper for this set up, only with Arena is enough, you will get more fps and more stability...
And this changes through out the track (therefor the need for multiple presets)
I know I could map each section of the input to a box face on the output but that would require me to run 13 videos at all time (I think). Also the Ableton-Resolume OSC connection only allows me to trigger one video clip with one audio clip (without a lot more mapping complexity and limiting the flexibility of the performance etc.)
Thanks for the SSD drive tip. If I were to load all the DXV files onto an SS thunderbolt drive would that provide better performance than a better Video card?
