Serious deck and channel problem!
saikocurve
Post by saikocurve »
I just bought Resolume 2.0 Beta 2 and I'm having some serious problems with using the decks and channels. First of all i saved three decks. Then when i tried to move from the top deck to the other decks the images on all the channels were correct on the decks but the clips loaded on them were all confused! When i clicked on the channel image it would play the wrong clip. The layout of the top deck seems to be copied to the other decks erasing the clips but leaving the image of the original clips loaded on to those channels. I erased the decks and started again but the same thing happened. Can anybody hep me with this?
