Hi guys,
i'm doing a project in which the image in a layer need to move on the Y axis of the composition.
I'm receving some dmx data from a arduino sensor via Artnet. (the screen is physicaly moving, and we are overshooting with the projector, and need the layer position in resolume to follow the movement of the screen) Everything is working fine on that way.
Here is the problem :
Why is the value of anchor Y is so big (-8192 to + 8192 ) ? What does that value represent ? Can it be changed ? Because now the movement sensor is sending signal from 0 to 127 (in dmx signal) Of course it's not working at all to link the DMX value to the position of the layer. The value is way too big
Could the be a way to link a mathematical expression like : DMX value / whatevervalue = layer anchor Y
thanks
