Hi there
Next week I have a gig. But I can't take my pc with me so I can use a laptop from a friend that comes with me. He got Resolume arena aswell. Now I want to put the saved composition from a usb stick onto his laptop in Resolume with the same hardware that I use on my pc. If I put the saved file on his version do I have to program everything or is the setup ready to go? Is there someone that has try that?
USB stick
Re: USB stick
Arena has a clip reconnect feature, so when you open your composition on your friend's computer, you can reconnect all the missing footage. Take a few hours in advance to do this so you can make sure everything has reconnected correctly.
Don't forget you'll have to copy all your content as well!
