Display a lot of Pictures
BlackBuda
Post by BlackBuda »
What´s the best way to load and display a lot of pics ? (near 100 jpg)
Any schema like the Visual Jockey R3.5 plugin: auto load pictures ?
[]´s
BlackBuda
Danger
schema....maybe !!!
Post by Danger »
i don't know how does VJ R3.5 plugin works
but the only way i see to use on resolume is to add load the images on one Movie Deck and resolume make it like one movie with each frame 1 image.
This way you can have lots of images load
james res
Post by james res »
why not just ACDSee
http://www.acdsystems.com/
if its just for displaying pictures
Danger
it\'s just to display images ?
Post by Danger »
it's just to display images ?
if so even winxp do that :P
edwin
Post by edwin »
if you drag a folder of images into a channel all pictures will be loaded in that channel.
normally when selecting files file by file you can only select upto 20 files at the same time.
so drag a folder and you are ready to go.
the picture playback has improved a lot.
use bmp,s or jpg's to get the best result.
pictures will allways be scaled to fit the entire screen, so it doesn't take care of the proportions. that's on our todo list.
cheers
Edwin
BlackBuda
Post by BlackBuda »
"Danger:
if so even winxp do that "
"James Res
why not just ACDSee
if its just for displaying pict"
Well, I talking about do that inside Resolume ;)
I Think Edwin is the only that understand it.
If this work i will release the .swf and the .fla
Let me try to explain (my english is +-)
While I VJing a gogo-dancer keep making some photos from people around the party, after do that her send me the stick card.
After select the best pictures i start to display it inside resolume mixing with the footage, but i got many photos and load 20 by 20 is boring (near the 4 am), move 1 by 1 to layer.... :o , I´m a good soon and my fingers on pain :cool: my mouse on fire.
My idea is:
(after I understand cool how the rparameters work inside flash)
make a flash that load and display the pictures and control the time interval from a rparameter.
I have 2 weeks to do it.
If this work I´ll release the .fla
I Will try to buy Resolume near 01/2005 (beta or full, but I Will try, of course I´ll win a t-shirt).
Why don´t buy today?
Simple: Because i Don´t have money :D
I Believe: God on Heaven, Resolume on the danceFloor.
This Software is great, really great.
Very fucking good job.
[]´s
From Brazil.
[Edited on 25-10-2004 by BlackBuda]
Danger
Post by Danger »
money....money....a global problem :)
BlackBuda
Post by BlackBuda »
Help BlackBuda to buy Resolume
To donate just send me the money :D
Danger
Post by Danger »
just give me your acount number and i'll think about it :D
BlackBuda
Post by BlackBuda »
Really? :o
:D
