Problem with AMD-Grafics and large comps
OS - Win 7 64bit
Graficcard - 7970M
CPU - i7 3820QM
RAM - 8GB
Hi everyone,
I allready send this behaviour to resolume via email...but I am very interested if I am the only one having this issue.
As you can see in the picture above...here is something wrong. This happens when I set my compsize to
1920x480px (and larger) for a TH2Go setup (3x 640x480). On my physical outputs the picture is intact...only ..the Output Monitor and the Preview Monitor inside of resolume are totally mashed up.
Resolume crashes immediately when I try to rescale the Output/Preview frames. Now...a AMD popup appears "....AMD driver crash"
When I'm using some std. resolutions for my composition...something like 1024x786px everything seems to work fine ...except of that the fps text and the preview video inside the Prev-Mon is smashed while the frame is scaled to a minimum. (picture)
Does anyone has an idea? pleaaaaaaaaaaaaaaaaaaaaaaaaaseee :cry:
Greetz
Re: Problem with AMD-Grafics and large comps
Do you know this feeling when you solved something by yourself? :mrgreen:
I was sooo upset the last days because of this....grrrrrrrr...S**T
AMD just released a special mobility catalyst package....from now on you are not longer depending from your notebook company to give you the latest "modded" drivers. In my case - DELL.
I just installed this catalyst version: LINK!
...and all troubles where gone. I'm soo happy now.....All I have to do now is to buy a bunch of celebration beer!!
Greetz
BIG EDIT:
My happiness was a bit to early :cry: With the new driver the crashes and the visible clip cancer were blown away...but now my complete output started to flicker massively!!!
LINK to kmifflings Topic - Broken AMD support!
viewtopic.php?f=12&t=9714&hilit=flickering
HerrNieDa
Post by HerrNieDa »
hmm, 12.3 catalyst works (on a Desktop 6970).
mobility modder maybe helps? (used this tool for my old laptop with x1600).
a friend of mine installed a 7970 Desktop with 8 Screens , i can ask him which driver he uses!
Yes...would be great... thx
