Hello Everbody,
I´m Using arena 4 with 2 HD5770 Cards. With Disabled V-Sync I have 80FPS. But alls Screens working with 60FPS. So If I playing a Video there are dropped frames (because transforming 80FPS to 60FPS). When I enable V-Sync with every Monitor I add Ig et half Frame Rate. With 3 Outputs I have 20FPS.
Is thos problem also with two Nvidia Cards? Can I Use with 3 Outputs V-Sync or is it the same problem like ATI Cards (3 Outputs V-Sync = 20FPS)?
Is there an alternative to Triplehead2go to get Synced multiple Output without dropping Frames?
FPS problems with multiple Output and activatd V-Sync
Re: FPS problems with multiple Output and activatd V-Sync
If your videos are a normal framerate (25 or 30 fps), you won't experience dropped frames when Resolume is running at 80 fps. The only issue is possible tearing on the output.
Which Graphic Card should i Prefare Nvidia or ATI?
Do I have no Tearings with multiple Outouts with Nvidia?
