will resolume 2 work on windows 7?
eye fidelity
Post by eye fidelity »
Hi all. How can i get my old resolume to work on windows 7 ?
Also is there a res 2 version for windows 7?
I don't need avenue. Just moved over to 7 from xp.
Please help?
vj granda
Re: will resolume 2 work on windows 7?
Post by vj granda »
It works for me...
eye fidelity
Will try........... Are you running it through xp vitual or windows 7?
vj granda
Post by vj granda »
W7
eye fidelity
Well w7 just shuts res 2 down as soon as I try to load a clip into a deck.
It works on the vitual xp. But I want to use it on w7
HerrNieDa
Post by HerrNieDa »
does it happen with every clip?
maybe it's a bad codec.
vj granda
Post by vj granda »
Yes, take a look at the codec, are You using Indeo? Because It Isn't supported by W7. There is a way to force Indeo to run in W7, You can do a search in this forum... But the better codec I think is Mjpg...
eye fidelity
Its a new pc so have not added any codexs. Just using the one if any it came with
eye fidelity
Any suggestions for FREE codexs that will work on w7?
eye fidelity
Forget everything. My 2.3 works great now. Thanks for your help. BUT I cannot get the screen set up settings to talk to the projector at all on windows 7. Really frustrating. Never a problem in eight years on xp. Grrrrrrrrr. Any suggestions anyone?
