First of all thanks for your awesome software ! It's really powerful by now and one can achieve so many stuff.. that s great
I was wondering if it would be possible to add the possibility to blend the different slices outputs in the Arena Mapping manager.
Lets say you want a setup like this.
if you set your input like this:
you end up with an output like this (no matter the stacking of layers you do, you always have this black overlaying)
Would it be possible to put an Add/Blending mode to the Output slices ?
other solutions:
- a Black to Alpha option for the output slices
- possibility to define geometric masks inside the inputs
thanks a lot !
