copy Clip Properties
etv
Post by etv »
is it possible to copy the properties of a clip and paste them to another clip (clips).
I have to animate some Logos and will have them all to move the same way (zoom, move and rotate is applied on that clip). So adjust every single clip is the hard way *g* - is there a way to copy the properties only?
To do so with the moves applied on a layer is not possible in that case.....
thanks
etv
Rene
Re: copy Clip Properties
Post by Rene »
I think it's not possible to copy clip properties in Resolume. But you could try the same approach mentioned here: viewtopic.php?f=6&t=9841
etv
Post by etv »
Hi Rene,
thanks - yes that plugin would help me!!!
greetings
etv
Also, you could copy the clip, and then replace the content (you can replace the content by dragging a new clip over the video tab).
