Save Presets on Transform Panel...
I would like to be able to safe presets for example on a clip in the transform panel. What i do a lot is creating a animation with the timeline feature then slow down the speed set in and out points on scale, then i have to do that over and over on multiple images, it be great if i could safe presets and just recall them on the other images or clips i have, would safe me a lot of time...
Re: Save Presets on Transform Panel...
WoW what a great plugin, i will use that for sure a lot of times
