Hello,
This will be my first post ever and I really hope I don't ask something which has already been asked, that would be a bad first impression...
Since the latest update, my cue points don't work properly.
I don't see any letters (q/w/e/r/t/y) at the cue point buttons.
I can press the triangles at the left of the buttons, and when i press the buttons where the letters should be, the video does jump to the right point. but when i push q/w/e/r or t, is doesn't.
Cue points are pretty useless when they don't work with my keyboard, so I hope someone can help me!
There is a chance I just did something wrong with the settings, but I can't find the problem myself.
Cue points
Re: Cue points
You probably cleared or deleted the default Application Key Map. Just go to Mapping > Application Key Map and assign the QWERTY keys again. The 'assign cue point' buttons were mapped by SHIFT+QWERTY.
Re: Cue points
I can't remember changing that, but it worked anyway. Thanks!
