Roll Transitions drop back frame after 180 degrees.
If the transparent logo or image or clip on the previous png is larger than the one replacing it, you can see it, oddly not in reverse, for a frame or two after it hits 180, then it drops. It's ugly. 90 should be selectable or even the default.
Re: Roll Transitions drop back frame after 180 degrees.
This is a problem with transitions on clips with alpha channels. You will see it on the normal transitions as well. It's on the to-do list.
Awesome! Is there a todo list I should be checking before posting things I find? I do try forum searches, but it's kinda hit or miss.
This alpha issue bites. I had a logo intensive show this weekend that was a real pain without good transparency support. Do you need any data collected or tests run? How can we help this one get fixed?
How's your c++/openGL?How can we help this one get fixed?
Send me a NDA, I'll even go buy a mac mini...
