Hello.
Not sure what to call this, I'm from 4 years of VDMX but testing out Resolume for it's speed benefits. What I'd like to do is to set up control surface presets, so if I'm in preset 1 my effects will be audio driven, preset 2 will be LFO etc (or a mix).
Is this possible?
Cheers.
Presets, or composition presets.
Re: Presets, or composition presets.
Resolume does not really work with control surfaces. However, every effect can have different presets, in which also different animation options can be saved. Check out the Resolume effects video for more info (the preset bit comes toward the end): http://vimeo.com/11893543
Hope that helps!
Hope that helps!
Ahh, ok, thank you. I'll take a look.
Cheers.
Cheers.
