Akai MPD 26 mapping?
KNanosect
Post by KNanosect »
Does anyone have a mapping for this controller. I've tried mapping it myself. I'm currently using v.3 (its just most comfortable for me). I'm running video for a Mark Instinct & Mayhem show comming up and really want to use the midi!
Basic
Re: Akai MPD 26 mapping?
Post by Basic »
what seems to be the issue? - are you looking for a template already?
Is it showing up in prefrences?
vj8k3
Post by vj8k3 »
Basic wrote: โ†‘Fri Dec 28, 2012 13:07 what seems to be the issue? - are you looking for a template already?
Is it showing up in preferences?
im trying to do the same thing idk if the answer is solved
๐Ÿ‘ฎโ™Ÿ ลŸ๐•„๐•†โ“šแ—ด โ„‚ัโ“โ„ƒ๏ฝ‹ ๅ„๏ผกฮนฤน ๐“ˆฮ”โ“‰๐’ถล‡ ๐Ÿ˜ŽโœŒ
Asus pro duo
Intell cor I7
16 gig ram
Gforce rtx 2060
mouse
Does your computer show the connected device? Can you no map the device using the MIDI shortcuts menu?
