Hi
I managed to get this working well on one win 7 laptop. But.... When I try to connect between two laptops using an adhoc network, I am having a nightmare getting anything working with the dispatcher. As far as I can tell I have the network set up correctly, have identified the ip addresses, and input destination address into dispatcher but no joy!
Anyone have any suggestions? resolume 4.1.1 ableton 8.2.7 both win doze laptops.
Getting Max 4 Live patches to work
Re: Getting Max 4 Live patches to work
In general, when troubleshooting these types of problems, you have to follow the signal flow to see where the chain breaks.
In this case, we can assume that the M4L patches are sending, but are they actually arriving on the other computer? Maybe they are caught in a firewall?
I don't know of a simple tool that can check for incoming OSC messages on Windows, but you could try the Processing oscP5 library for instance.
