. AND ,
. AND ,
Hi Resolumes,
simple proposal. I would like to enter values like 20.5 also with a comma 20,5. Why? Because I have powerful numpad skills. ;)
Cheers
Re: . AND ,
We'll take a look if we can fool Resolume into thinking commas are decimal points. Don't hold your breath though, 20,5 usually makes a computer think you are inputting two values, 20 and 5. If you want to use your mad numpad skills, set your keyboard layout to US, it will then interpret the numpad decimal point as an actual decimal point.
Re: . AND ,
Thanks for take a look on it. Shure...I can use the US layout... but I love Ää Üü Öö 8-)
HerrNieDa
Re: . AND ,
Post by HerrNieDa »
i just used a tool on an old laptop to deactivate a key,... remapping a key should also be no problem
https://www.question-defense.com/2010/0 ... e-keyboard
