Just downloaded MPEG Stream Clip1.2 but I can't find the Compression Type DXV anywhere?
Got it on the Mac version. Any ideas?
jens_lights
						MPEG Stream Clip Encoding Windows
Re: MPEG Stream Clip Encoding Windows
reinstal dxv codec after installing mpg stream
				jens_lights
Still no luck ...smogg wrote:reinstal dxv codec after installing mpg stream
do you use any other software like After Effects or PPRO?
						- Stickygreen
In MPegStreamclip
load your video, then select file from the top menu, and choose export to quicktime.
open the pull down menu at the top labeled: compression
choose DXV compressor
adjust the rest of your settings and your good to go.
				jens_lights
I know the steps to convert a video, it's just that the option DXV is not there. I have it on my Mac.
No, don't have anything such as After Effects or else installed on that machine. It's all on my Mac and DXV shows up as an option there.
I supose you have Quicktime installed... May be try to reinstall it.
As Granda mentions, make sure you have Quicktime installed in the default location.
The reason why Sticky mentioned the steps to export was because you didn't include this information in your original report. When all you say is "it doesn't work", there's no choice but to start at basic principles in order to help you.
				jens_lights
I see... I reinstalled Quicktime and the DVX codec but still no joy.
I think it's time you contacted us directly (mail@resolume.com).
