Hello capture world!
I have a blackmagic drama i hope some expert had gone through and have the solution
I have blackmagic intensity shuttle usb3 and resolume 4 on win7x64.
- if i install the official drivers package from blackmagic website it also installs a lot of other wrong-ware including blackmagic mjpeg codecs that wipe out all other codecs and make resolume4 work very slow with mjpeg avi clips.
- i managed to extract the drivers only from another windows installation and installed them on the resolume windows, however now resolume doesn't recognize the blackmagic - it's not in the sources tab.
Do you know any solution to make blackmagic work in resolume without installing blackmagic's mjpeg codecs?
Thank you!
Deyan
Installing BlackMagic drivers without installing BM codecs
Re: Installing BlackMagic drivers without installing BM code
[post moved to new topic]
