iPad to Arena?
BigFatPaulie
iPad to Arena?
Is there a way to get an ipad app to show up as a source in arena for mapping? I want to use a drawing app so people can do live drawings on my map.
Re: iPad to Arena?
Hi BigFatPaulie and welcome,
Yes there are a couple of ways you can do this.
A. Wired
- You'll need an "Ipad connector -> HMDI Adapter" and a capture card..something like the "Blackmagic Intensity Shuttle" for example...and of course a good HDMI cable.
- The capture card shows up in Resolume as an input device.
B. Wireless
- You can do the same like above....just use the AppleTV instead of a good HDMI cable, and the adapter
C. I'm pretty sure that somewhere out there is a tool which allows you to cast your ipad screen through a wlan to your pc/mac which also shows up in Resolume like a webcam or so.
But DAMN!!! I do not have this information for you!
Enjoy
A. Wired
B. Wireless
Enjoy
Do you like outlines? Easy Outliner on Juicebar -
BigFatPaulie
Re: iPad to Arena?
Awesome thanks! I'll look into the blackmagic card. I think my company purchased one just now sure the details on it.
instead of Apple TV i just bought AirServer so i can stream it right to my mac but i don't know yet if resolume will read that as an input.
thanks again
-Brian
thanks again
-Brian
Re: iPad to Arena?
No Problem!
Please tell us when you find a solution for the AirServer problem...
Greetings!
Greetings!
BigFatPaulie
Re: iPad to Arena?
Got it! Thanks to the Resolume Blog. I was using Tagtool and came across the webpage that had a step by step process on it I'm going to give other drawing apps a shot too.
I'm really happy about this because i bought AirServer before i found the the tutorial.
Re: iPad to Arena?
wonderfull! I wich you a lot of fun!
