analysis ultra 2015 pixelmapping
kinksid
Post by kinksid »
so many screen ! !
i noticed when the LED strobe not at same beats but individual several part
did they use some trick to get the beat ?
how they do it
how to separate to apart and be a whole when appear logo
He2neg
Re: analysis ultra 2015 pixelmapping
Post by He2neg »
I cant realy see any question in your post, what do you need / want exactly ?
maybe they use some effect like videowall with variable brigthness to strobe in some different style then the whole area.
~Berlin~
dirtyjohn_lv
Post by dirtyjohn_lv »
Since it's the main stage, it's most likely Epic MK3 from V SQUARED running everything, not Resolume.
Although this post was about Dance Valley, the idea is the same. It's all about creating a good input map in your composition: viewtopic.php?f=5&t=11599&p=47032&hilit ... ley#p47032
Btw, I've not been at Ultra, but from what I gather, most of the V-Squared guys were running Resolume. KBK Visuals and Eyesupply were doing visuals for some of the headliners and they were all running Resolume. Epic sounds like a brilliant piece of work though, I hope I can see it in action at some point. Either way, you still need to create an input map to be able to put a good show on a stage like this. Which software you use to do it is irrelevant really.
rawdesigns
Post by rawdesigns »
that would be rad if they had a stage that was as big as the main but just 1 flat giant LED wall :shock:
drazkers
Post by drazkers »
rawdesigns wrote:that would be rad if they had a stage that was as big as the main but just 1 flat giant LED wall :shock:
For an artistic guy I expected more vision. :lol:
kinksid
Post by kinksid »
Joris wrote:Although this post was about Dance Valley, the idea is the same. It's all about creating a good input map in your composition.
tks joris, i have one more question
you'll notice one thing if you've watch the ultra live
they do the strobe effect exact sync to beat as different part LED, is that sync by SMPTE ?
i think it impossible by rehearsal manual
hookerbot
Post by hookerbot »
I believe it was Eyesupply doing main stage this year, not V2. Correct me if i'm wrong.
najrock
Post by najrock »
dirtyjohn_lv wrote:Since it's the main stage, it's most likely Epic MK3 from V SQUARED running everything, not Resolume.
last couple times I saw them they had resolume and touchdesigner running together... touch mapping the walls and resolume serving up the clips.
this workflow is getting more and more common from what I can gather... myself included
