Arena locks camera
skagla
Arena locks camera
Post by skagla »
Hello everyone =)
I've a problem when I use Resolume Arena5 in combination with other applications that Arena locks the camera and I can't use it within other applications.
Use case:
I have an application for tracking where i need the camera input.
I use Arena for the video output.
But when I start Arena, it locks all capture devices it can find in Sources and I can't use the camera within my other application. (I don't need the live camera feed within Arena)
Is there a way to restrict Arena to only use some, or none, Capture Devices?
Thanks in advance
jo
Re: Arena locks camera
try starting the other app before arena
skagla
Post by skagla »
I tried it, but it's more of a work around.
At the moment I have to restart the other app quite often... and this results in restarting arena also ...
Are you using a capture card or a USB camera?
and are you sure you aren't using that camera in a clip in arena?
that should not happen that arena would lock a camera source, unless it's in use in the deck.
And a camera clip is considered in use if it's present in the active deck even if it's not triggered.
skagla
Post by skagla »
Thanks for the answers so far. I played around and called the technical support of the camera, but I didn't get any further.
I'm using an IDS UI-3360CP USB3 Camera on Windows 7
Is there any possibility to turn of DirectShow inside Arena?
