Hi Guys,
Bottom left red text with LOW MEMORY!! how is that possible
Setup:
Intel Core i7-2770
MSI H77MA-G43
ASUS R9 290 directcu ii oc
12 GB RAM
Windows 7 64x
Samsung SSD
who can help me!!
Resolume Arena 5.0.1 LOW MEMONY!!
Re: Resolume Arena 5.0.1 LOW MEMONY!!
Yes, easily, if you are working with many big PNG files, for instance.
working only with .mov and 1920x1080!
.mov is a Quicktime container not a codec and could contain many different codecs that can be lossless such as Animation or lossy such as Intermediate, ProRes, DXV, H.264 etc....
As Joris explained very well it in a post not long ago, Resolume can work with a lot of different codecs very well but the moment you start using multiple layers, compositing or have a lot of them in a deck using DXV is a must to get better results.
To give you an example, a couple years ago I was working on a big event and for some reason I kept getting the red "low memory" warning and Arena would crash. It turned out I had forgotten to encode a dozen 2-second .mov files from ProRes4444 to DXV and even though these movies were super short, they would crash my high end server. I had a lot of things going on in my deck but the moment I converted these files to DXV, all crashes were gone!
How many .mov and 1920x1080 pics do you have in a deck?
I have 50 .mov! than 1 with only snow and 8 for dj names.
Are all your .mov files in DXV3 codec? If not, then that's your issue.
