Hey I'm having trouble syncing up vj edits of music videos. I'm using cue points to sync (i know i should use SMPTE). You can see that Resolume playback is much faster. I've seen this happen before and if i make a new composition it usually troubleshoots the problem. my speed is at 1.00. you can see in QT the correct speed. Thanks for the help.
DXV3 video
6gb 970m
i7 6700HQ
https://youtu.be/Z9yI5LJWrnw
R5 playback faster
- rawdesigns
Re: R5 playback faster
Right click on this bar to make sure your composition speed is set to 1:
Clip set to BPM sync rather than timeline?
