Full HD Resolution
afriandhie
Full HD Resolution
Post by afriandhie »
Hi guys..
Im from indonesian..
im use resolume 5.0.4
i wan ask about resolution video
can i play full hd {3840 x 2160} on 1 layer in 10 columns or more :?:
thanks for help.. :)
sorry if my english bad
francoe
Re: Full HD Resolution
Post by francoe »
Is hard to undestand what are you asking for.
Columns are something like an array between layers, in example,
Column 1 means:
clip 1 layer 1
clip 1 layer 2
clip 1 layer 3..
So, playing a 'column' will play only one clip per layer.
About resolution, full HD is 1920x1080, your size is common 4K. If you want to knonw if resolume can play it, the answer is YES. It depends of your hardware, there's not a limitation on the resolume side (at least on my knowledge).
In fact, you will find guys playing far bigger resolutions around here.
Since you're using one layer only, as long as you use DXV3 codec you should be able to play 4K content on just about anything.
