Hi All,
I have installed the latest two upgrades for Resolume Arena,
both of which are giving me issues with audio output.
I also recently upgraded to Mac OS 10.12 Sierra, and I am wondering if this is the real route of the problem.
I have been working on a project for a few weeks with no issues, and suddenly I lost sound output. This loss occurred at some point after updating my OS and updating resolume.
Now, I am not getting sound output when I play any of my media (video with audio, or audio .wav files)
I have checked all the volume levels on the composition, layer, and clip levels, and they are all normal.
I have tried playing audio outside of Resolume on other applications, all of which work as expected.
When I play a clip with audio I can see it metering in both the layer and the audio equalizer.
I have tried opening a new composition and still have the same issue.
I have a tour coming up in about a two weeks, and rehearsals next week, so I really need to get this resolved asap!
Any help would be much appreciated!
THANK YOU!
No Sound Output From Any Audio Output device?
Online
- Team Resolume
Re: No Sound Output From Any Audio Output device?
when you open preferences/audio you can choose an output device, have a look at that, maybe the device you used got renamed and has to be selected again.
I have switched between multiple output devices in the preferences. No luck.
Online
- Team Resolume
have you checked composition volume setting, and also layer audio sliders?
Yes, all volumes on all layers, clips, and composition are up.
Online
- Team Resolume
try moving/renaming the config.xml, so resolume can start with default settings.
That solved it!
Thanks ravensc!
Should I replace the .xml file?
Thanks ravensc!
Online
- Team Resolume
no, but you should check the Preferences, that everything is set up as you need it to be.
The problem has returned!
I have attempted to remove the config.xml and Resolume is still not outputting audio.
Our show opens on Sunday. Need a solution ASAP!
Best,
Max
Best,
Max
What audio output/hardware are you using?
Have you tested with a headset?
Have you installed new drivers that could conflict with your audio drivers?
Do you see the audio meter moving in Resolume?
