MA 1 OnPc Issue
ferluces
MA 1 OnPc Issue
Post by ferluces »
Hi, I want to connect Resolume Arena 5 with a MA1 OnPc Console.
In order to buy a License, we are testing with a Demo version, but, we can´t connect them.
Here is my set up:
PC notebook, Windows 7, MA1 OnPc 6.808
Ip Address 1: 192.168.3.110 Net Mask: 255.255.255.0
Ip Address 2: 2.20.245.86
Mac computer: Ip Address 2.20.245.87- Subnet Mask 255.0.0.0
2port Node Pro - Arnet Mode Ip Address 192.168.3.109
Everything cabled via an ethernet switch
Please, help me!!!
Re: MA 1 OnPc Issue
A few questions:
  • - I'm assuming you're using the 2.x.x.x/8 for Artnet
    - You have Arena installed on your Mac computer, right?
    - If you're using Artnet, why is your Mac on 2.x.x.x/8 and your 2port Node Pro on 192.168.3.x/24
    - Why are you using a /8 subnet (255.0.0.0) instead of /24 (255.255.255.0)?
    - Are all you subnets set the same on all devices?
    - Is your 2port Node Pro working?
    - Can you give a schematic of your current setup?
ferluces
Re: MA 1 OnPc Issue
Post by ferluces »
Sorry... my mistake. I´ve been researching a little and i realize that ip´s
have to be 2.0.0.xx. That´s right?
How could you set up this?
The 2port node is working... i can "see it" on connection...
Re: MA 1 OnPc Issue
If your 2port node is working then your MA1 is communicating on the 192.168.3.x/24 network so set your Mac to 192.168.3.x/24 (255.255.255.0) and you should be set.
I'm curious how everything can be connected to an ethernet switch and still have your Mac on 2.x.x.x/8 and your 2port Node Pro on 192.168.3.x/24.
Does your PC have two ethernet ports or is the 2port node connected to a wireless router? If so, make sure you're either connecting your mac to the wireless router and not the 2nd ethernet port or use a switch between your PC, 2port node and Mac.
Re: MA 1 OnPc Issue
as Oaktown said, you need to set the ip addresses to be on the same subnet range, otherwise they won't be able to communicate properly without building a good routing table.
so it's best to use manual ip assignments for a few devices.
having different subnet/ip ranges on the same switch will work just fine for each, but subnets won't be able to talk to another
