Wishlist and Bugs
movebandit
Wishlist and Bugs
Post by movebandit »
Hello Resolume Team,
heres a short list of things i noticed in my work and could be some useful minor and major changes for optimizing the workflow:
-BUG:Duplicating a Lumiverse doesn´t name it "name"+Copy
-WISH:Artnet Span one fixture over more Universes automatically
-WISH:Select more than one Lumiverse to Set Framerate, Brightness, Output etc
-WISH: Bring the Deck list back (When using a lot of Decks the Name of the Deck is not readable)
-WISH: set cue points midi out (For Colour feedback on Controller, Cuepoint set or empty)
-WISH:Tagging for files and decks (Set Tags and search for them, like colour, Style whatever)
-WISH:Be able to Delete file behind persistent clips
-WISH: Composition Browser: Close all Deck-Tabs
-WISH: When loading a Deck from Composition Browser, keep Cursor on Place (When compiling new compositions from old ones, i always have to scroll down again after loading a Deck)
-WISH: Select more than one Deck for Removal (ctrl or shift)
-WISH: Define Crossfade time and Style for single clips, not only a master time for the layer
-WISH: Define a loop repeat number or time for Autopilot
-WISH:Set a midi velocity mapping standard (for active colour feedback)
-WISH: Transform Parameters shown in percent, better show in pixel
more to follow....
Re: Wishlist and Bugs
movebandit wrote: Mon Jun 11, 2018 20:57-BUG:Duplicating a Lumiverse doesn´t name it "name"+Copy
Duplicating a Lumiverse adds a number to the end of the Lumiverse name. This is the same as a screen or slice duplicate works.
movebandit wrote: Mon Jun 11, 2018 20:57WISH:Select more than one Lumiverse to Set Framerate, Brightness, Output etc
Already possible with command + click.
movebandit wrote: Mon Jun 11, 2018 20:57-WISH: Bring the Deck list back (When using a lot of Decks the Name of the Deck is not readable)
Are you looking for the Compositions panel?
movebandit wrote: Mon Jun 11, 2018 20:57-WISH: set cue points midi out (For Colour feedback on Controller, Cuepoint set or empty)
Works with my APC 40 mk2.
movebandit wrote: Mon Jun 11, 2018 20:57-WISH: When loading a Deck from Composition Browser, keep Cursor on Place (When compiling new compositions from old ones, i always have to scroll down again after loading a Deck)
This is actually a bug. We'll see what we can do. (#11331)
movebandit
Zoltán wrote: Tue Jun 12, 2018 14:47
I was working with around 60 Lumiverses and they were named like C1.7.3 U54 S27a 3.4 (Controller1 Output7 Strip3 Universe 54 Stripnumber 27 Subnet 3 Universe 3)
When copying the lumiverse it doesn´t call it C1.7.3 U54 S27a 3.4 copy (which would be nice just to rename the parameters) but "Lumiverse 1"
Would be fine to use CMD+A and SHIFT+click. Did you ever selected more than 30 Lumiverses by CMD + click... ? ;-)
Nope. Under the Clip Panel, the actually loaded Decks are shown. When there are too much, the name is not readble. Solution in Res5 was a popup window with the actually loaded decks.
Doesn´t work as it could. The Status Velocity is only On and Off, but it would be helpful to have a Status like "Set" and "Empty", to directly see if an Cuepoint was saved or is empty.
Nice!
Some new ones:
WISH: Implement the Fixtures in the saved Screensetup. When sending Screensetups as inputmaps for other VJs we always have to send the Fixtures additionaly. Wouldn´t it be easy to save them together with the Screensetup ?
WISH: Next Button ("N" ?) for selecting next Slice, Highlite Button ("H" ?) for switching selected Slice to White. Helpful, when working with a lot of Slices and Integrated in nearly every Light Console...
WISH: Switch Lumiverses from xx:Subnet xx:Universe to xxx:Universe (Some Controllers display only the decoded number of the Universe and not subnet /universe. Less Calculator use..
movebandit
Another One: WISH:Move Persistent Files in actual Deck. Works with copy and paste, but could be a function in the menu...
drazkers
Post by drazkers »
movebandit wrote: Tue Jul 24, 2018 16:16
Nice!
Some new ones:
It really helps me out having fixtures as a separate file In a logical file structure. Id personally not be into this.
